MPC5746r SRX module example code
nickvt
Is there any example code available for the SRX (SENT reveiver) module in the MPC5746r mcu?
lukaszadrapa
it is written for MPC5744P but may be useful also for MPC5746R:
https://www.nxp.com/docs/en/application-note/AN4856.pdf
https://www.nxp.com/docs/en/application-note-software/AN4856SW.zip
Lukas
mvogtmann
is the driver and API library also compatible for the MPC5777C?
Another question regarding SENT, besides Interrupt or DMA transfer, is polling of the Fast and Slow Data Registers with a ms timer interrupt possible?
