S32DS Jenkins build under Windows 10
dan_teodorescu
I am setting up a Jenkins CI system under Windows 10. This requires that I run a scrip (build.sh) under the msys that comes with S32DS; the script does all the work, and exits once the build completes.
I noticed that the S32DS utils/msys32 has three executable: mingw32.exe, mingw64.exe and msys2.exe. It's not clear which executable to use and what the command line interface expects.
In summary, what exact Windows command should I issue such that the S32DS msys environment executes my build.sh script?
Thank you,
Dan
Tags (2)
jiri_kral
best way how to startup msys command line is use msys2_shell.cmd . This script starts msys and set for you paths and other  environment variables.
Jiri
