Hi, in the schematic of MML09212H you say that R1 is connected to pin 12, but on the layout you connect it to pin 10. Which one is correct?
Thank you for your time.
Solved! Go to Solution.
You are right, in the datasheet connection of R1C7 in the schematics differs from that in the layout.
Though, the connection order of R1C7 to pins 10,12 or pins 12,10 does not matter. Both provides the same functionality.
So, we have no serious reasons to fix this discrepancy in the datasheet.
Pavel
Pavel
