Unable to interface External NAND Flash through NAND Flash Controller
jyotiranjan_bal
We are using MK60FN1M0VLQ12 microcontroller for our application and we are facing problem interface external NAND Flash through NAND flash controller.
I attahced NAND Flash controller configuration,NAND flash controller code and problem we are facing on interface.
Could any one please help on this issue ?
External NAND Flash Part no : MT29F8G08ABACAWP-IT
Jyotiranjan
Hui_Ma
I checked you had submitted the same question at online service system.
Please check my reply at Case Number:  0189673
Thank you for the attention.
Mike
