Building multiple SREC files
Question asked by Jing Yin Wong on Nov 25, 2018
Latest reply on Nov 26, 2018 by Jiri Kral
Hi NXP Team,
I have 2 version of S32K142 linker files (S32K142_32_flash.ld).
Each linker file has different memory area specifications.
I need to build 2 SREC files under the same project in S32DS with different linker files.
Currently, I have to perform the followings to build 2 SREC files:
1. Build the 1st SREC file.
2. Modify the linker file manually.
3. Build the 2nd SREC file.
I would like to know if there is any better way to achieve that.
For example,
#ifdef XXX
   run version1.ld
#else
   run vesion2.ld
Thank you.
Jing Yin
