franco dal pero
Problem in Power-Up on MC9RS08KA2
Discussion created by franco dal pero on Dec 18, 2008
Latest reply on Dec 19, 2008 by David Payne
Hi at All
I have chk one big problem in the production circuit when I have used the MC9RS08KA2 microprocessor.
In a 20% on  the Board the program not run correctly when the system is power-up. But in the board non function if I switch  more time switch-off switch-on the power the system start well.
The problem is in  the low rise time on power supply? or is the LVD problem?
There is any solution?
Franco
