How to program LPC2148 using NXP enplas device in keli software
swamy1
I have brought this device for programming LPC2148 now I am not able to program the IC using this module. And I am not able to find any videos for it how program the IC using this device. Can anyone please let me know how to program the IC using this device.
Thanks and Regards,
Thippeswamy H U
CarlosCasillas
At a glance, it seems that the board of the picture is just a socket-pinout board with debugger connector, so, you should verify the following basic points:
  1. Target processor is properly powered.
  2. Debugger is properly oriented and connected on debug connector.
  3. Processor is properly mounted and aligned on the socket.
For additional material about LPC programming, you could refer to the following links:
http://www.keil.com/forum/59179/programming-in-lpc2148/
https://www.nxp.com/docs/en/application-note/AN10302.pdf
As complementary point, the LPC2xxx family is now part of the legacy devices with limited support, so, if you are starting the development of a new project, it is recommended considering a newer LPC device like the LPC54000 or LPC5500 families.
Hope this will be useful for you.
Best regards!
/Carlos
swamy1
Please someone help me with this issue. Can anyone provide the schematic
of it.
Thanks and Regards,
Thippeswamy H U
swamy1
Please help me by sending schematic of the programmer. Error is due to
requirement of some additional components.
Thanks and Regards,
Thippeswamy H U
swamy1
Please help me by sharing the schematic of that IC socket board.
Thanks and Regards,
Thippeswamy H U
swamy1
Dear Carlos,
I have checked all three points. Everything is correct for your
reference I have attached the error and IC programmer which I am
getting. I am able to program the development board using same jlink and
with same settings but not using this programmer socket. Is there any
schematic available for this socket programmer. PFA
Thanks and Regards,
Thippeswamy H U
swamy1
Please let me know
Thanks and Regards,
Thippeswamy H U
