CodeWarrior Tap GDB server gives error when executing -data-evaluate-expression
Question asked by Zachary Wilcox on Nov 20, 2018
Latest reply on Feb 19, 2019 by Yiping Wang
I'm connected to the GDB remote server on the code warrior tap to debug the QorIQ® P1021|NXP :
I get the following error when running -data-evaluate-expression (uart)->rx_tx_dll
Failed to execute MI command:
Error message from debugger back end:
Cannot access memory at address 0xef004500
I get this in both Eclipse and GDB in the terminal.
You're help would be appreciated.
Zach
