Command_Line_Tools/mwldeppc|Linker|Error
Question asked by Ayush Agarwal on Nov 19, 2018
Latest reply on Jan 10, 2019 by Martin Kovar
I want porting a CW2.1 code to CW11.0 so for that i copied one by one .c and .h files. initially it was showing some function prototype missing errors but I have solved all. Now it is showing some linker error i.e
'Building target: HVAC.elf'
'Executing target #69 HVAC.elf'
'Invoking: PowerPC Linker'
"C:/Freescale/CW MCU v11.0/MCU/PA_Tools/Command_Line_Tools/mwldeppc" -o "HVAC.elf" @@"HVAC.args"
C:/Freescale/CW MCU v11.0/MCU/PA_Tools/Command_Line_Tools/mwldeppc|Linker|Error
>multiply-defined: 'IR_ValidLeaderPulse' in IR_c.obj
>Previously defined in IR_App_c.obj
>multiply-defined: 'IR_MultipleKeyPress' in IR_c.obj
>multiply-defined: 'IR_ValidMultipleKeyPress' in IR_c.obj
>multiply-defined: '.dwarf.IR_ValidLeaderPulse' in IR_c.obj
>multiply-defined: '.dwarf.IR_MultipleKeyPress' in IR_c.obj
>multiply-defined: '.dwarf.IR_ValidMultipleKeyPress' in IR_c.obj
>undefined: '__GALLO_BEGIN'
>Referenced from 'GALLO_SetContextDCU' in GALLO_c.obj
>undefined: '__GALLO_SIZE'
>undefined: '__VIU_BEGIN'
>Referenced from 'InitVIU' in VIU_c.obj
>Referenced from 'VIU_ISR' in VIU_c.obj
>Referenced from 'InitVIU_MC' in VIU_c.obj
>Link failed.
Errors caused tool to abort.
mingw32-make: *** [HVAC.elf] Error 1
While there is nothing redefined or undefined. I am bit confused if some library is missing there or it's about something else ?
