Rapid IOT not detected by Android App. ?
herve_saint-jal
I just obtain one Rapid IOT kit and everything seems to be ok on the kit side (BLE, temperature, ...).
If I check the bluetooth devices seen by my phone (ASUS Z00AD, Android 6.0.1), the IOT is seen (cf. RapidBLE detected by my Phone.png).
I installed the NXP Rapid IOT 1.2.0 app. on my phone, but I am not able to detect the IOT kit (RapidBLE not detected by NXP app.png). I tried many times, and resetted the IOT without success...
Have you any clue ?
Thank you for any help or suggestion you might have.
estephania_mart
Could you please try performing a reset as stated here ?
Estephania
herve_saint-jal
Tank you for your email.
Yes, I tried this reset, the unit seems to be correctly working : the
RGB leds respond correctly, the movement, tap, ...are responsive.
The sensors are working (the pressure value seems to be far from the
real value).
By the way, I tried the IDE and changed the "out of the box" demo asking
for a pairing code for the BLE.
It worked successfully on my phone, showing that the rapid iot kit
communication with my phone seems to work ?
But, again, the rapid kit is not showing when I use the Android app. to
detetect the device ?
I am puzzled with this IDE : how can I change the interaction (the app.
on the phone ?) with the "application" tab of the IDE ?
Sincerely yours,
Hervé
P.S. : I am very junior using your kit and IDE !
I downloaded the SDK, but I have to test it.
Le 21/11/2018 à 23:13, estephania_martinez a écrit :
NXP Community
<https://community.freescale.com/resources/statics/1000/35400-NXP-Community-Email-banner-600x75.jpg>
Re: Rapid IOT not detected by Android App. ?
reply from Estephania Martinez
<https://community.nxp.com/people/estephania_martinez?et=watches.email.thread>
in /Rapid IoT/ - View the full discussion
<https://community.nxp.com/message/1082946?commentID=1082946&et=watches.email.thread#comment-1082946>
estephania_mart
Could you please try reloading the OOB demo from the Rapid IoT studio to verify it does not ask you for a pin code after reloading it ?
Estephania
herve_saint-jal
I did that, and borrowed a phone (Samsung instead of my Asus) : it worked well.
Then, I think, it is linked with my version of Android?
Nex days, I would like to have a look to the part of the code dealing with the detection of the kit
using your IDE.
Thanks again for your help.
Hervé
