Hi I'm using LPC54018 MCU in my own board, I have configured respective pins from SDK to the LPCXpresso54018 board to myb own board with the same configuration the only change is: I'm using 208 package insted of 180 package.
There are some curiose things:
When I try with 32GB microSD card in Create directory step, result is: fail.
Debugging here is the problem
Solved! Go to Solution.
Hi Oscar Niño,
I suspect the issue is related to the hardware configuration, so I'd highly recommend you to port the driver example: sdcard demo to your own board at first, after succeeding, next move is to port the fatfs_examples.
TIC
Hi Oscar Niño,
TIC
Hi jeremyzhou
Thanks for reply, I did this. I don't know why my project hasn't worked but I'm pretty sure that it was by bad soldering, 'cause first we unsolder filters and connected directly, and it worked then we put again filters and it worked.
Oscar Niño
