I am new to DIGI community, I want to enable OTG support on the micro AB. I have used the following setup in order to enable OTG for the Micro AB:
&usbotg1 {
dr_mode = "host";
fsl,power-line-polarity-active-high;
disable-over-current;
&usbotg2 {
dr_mode = "host";
But, Unfortunately I am not able to enable OTG on the micro USB. When I try drmode = `otg` @usbotg1, USB1 in host turns off and no longer reads.
Kindly, let me know for any suggestions.
Thank you
