I have a question about dual camera with i.MX 6Solo.
In the reference manual, there is a block diagram below in Reference Manual. It seems Parallel 0 and Parallel 1 can input video simultaneously.
Is it possible to use two parallel port?
I used to hear Parallel 1 don't use as video input with i.MX 6Solo.
Sugiyama
Hi Toshishisa,
You can uses both parallel to input MX6Solo.
Hi, Bio
Thanks for the answer.
I understood.
Sugiyama
