Example KV44F256 for usage of eFlexPWM with 312ps resolution
katha
I am looking for example code to use the eFlexPWM with 312ps resolution  within a KV44F256. Examples I found in SDK only provide setting the dutycyle 0...100%.
Thanks and regards
katha
Hi XiangJun,
that is what my question was for: could you send me the clocks configuration within a *.mex file?
Thank you and regards
Katharina
xiangjun_rong
Hi, Katharina,
Pls refer to the documentation, which describes the nano-edge placement feature of the KV46.
https://community.nxp.com/docs/DOC-341621
Hope it can help you
XiangJun Rong
katha
Hi XiangJun,
could you please send the .mex file including the clocks configuration
Katharina
xiangjun_rong
Hi, Katharina,
I think the project does not use *.mex file, regarding the clock configuration, the clock configuration tools is not used, the clock configuration code for example PLL is integrated in the code in the main.c
XiangJun Rong
