What is the total number of IO lines available in FS32K146HFT0 ?
vt600
I have been looking through the datasheet to check the total number of IO lines available in the FS32K146HFT0. In the datasheet it not explicitly mentioned or I could not find. Please support.
danielmartynek
Have you referred to S32K146_IO_Signal_Description_Input_Multiplexing.xlsx
The file is attached to the RM.
vt600
Hello Daniel,
Thanks for the support.
I was just looking for the maximum possible I/Os. From the datasheet, it is noted that total number of I/O lines available from the comparison table is 128 . Excel file you have suggested was really helpful to understand various functions as a summery.
VT
