how to resolve the debug error??
varun_kumar
I am not able to debug
getting the following error..
gdbserver  :2345 /vsdk/ISP_Test_application.elf;exit
-sh: gdbserver: not found
please help me out soon..
Thanks in advance.
varun_kumar
at present it is showing these error
Error during file upload.
Could not write file: /home/developer/workspace/ISP_Test_application/A53/ISP_Test_application.elf.
Read-only file system
jiri_kral
Um, this is strange error. So - what's is your debug scenario?
Typical remote debug scenario for S32DS for Vision - Linux target is:
- Host PC with installed S32DS for Vision v2.0 (doesn't matter if host PC is running under Windows or Linux)
- Linux OS running on target EVB  - ideally OS image which is part of S32DS for Vision v2.0
- Network connection between host PC and Target machine
Jiri
varun_kumar
find the image below, and please let me what is the problemdebug config.pnggdb could not start.png
jiri_kral
Make sure that you are running linux on your EVB. If everything is okay - check if gdbserver is present on your EVB - simply login to your EVB and try to run gdbserver --version . You should see something like this:
Jiri
varun_kumar
there is no gdbsever on the target, so I should also install gdb on the target??
jiri_kral
Official OS Image already contains gdbserver. In my opinion better idea is prepare new SD card with official OS image. Here is guide:
https://community.nxp.com/docs/DOC-335023
Hope it helps.
Jiri
varun_kumar
at present is showing this
varun_kumar
