Problem occurred when checking for updates in CW 11
perhojfeldt
This happen when checking for updates in CW 11. Internet connection works fine so that's not the problem. Any ideas?
Per Højfeldt
BlackNight
It seems to me that you try to update from a local JAR file.
Go to the setting (Window > Preferences) and only have existing files/sites checked, for example only the NXP MCU update site:
I hope this helps,
Erich
BlackNight
I hope this helps,
Erich
perhojfeldt
Hi Erich
Found it. Unmarked local jar and every thing is is good.
Thanks for your help.
Per
perhojfeldt
Hi Erich
Thanks for your help but when I do (Window > Preferences) this is the picture I get.
Per
BlackNight
You have to check the available update sites as shown in my screenshot.
