Config Tools not working for MCUXpresso IDE
Question asked by David McLaurin on Nov 8, 2018
Latest reply on Nov 8, 2018 by Libor Ukropec
I recently got a hold of an LPCXpresso804 dev board and have started a project built off of the SDK for this kit.
Project is generated properly and everything seems to be working as expected except for the Config Tools plugin. Whenever I try to access the tools to check my peripheral layout I get the following error:
Note: The package I am using is the LPC804M101JDH24
Now I thought this might be due to some error with the SDK that I had downloaded. So when I went back to the SDK dashboard and searched for the same kit, I reviewed the default clocks/pin setups and both indicated the -JDH24  package(TSSOP-24) was being used. I then re-downloaded and replaced the SDK that I had previously imported, and built a new project; yet I am still seeing this same error come up when I try to access "Config Tools"
Any thoughts?
-David
