Not quite true. If you erase u-boot from the flash, you can boot from the I2C EEPROM which (at least on recent boards) contains an emergency flash load program. This will allow you to use a terminal emulator with the kermit protocol to reburn u-boot.
See the
Getting Started guide for more details. In the rev. 1 document, it's section 3.2.
