Does anyone have example code for MPC5744P FCCU EOUT connected to SBC IO?
juliusjai
I'm interested to know how I can send the FCCU EOUT reaction to SBC IO.
Does anyone have example implementation?
Thanks.
Tags (3)
petervlna
There is no code needed.
FCCU has 2 EOUT signals.
EOUT0 and EOUT1 which for this device are always connected to pins.
If you want to enable the fault notification for EOUT, then you simply configure Fault-Output (EOUT) Signaling Enable
(FCCU_EOUT_SIG_ENn) register to do it.
Each bit represents  NCF which will be signaled out if the fault is active in NCFS_x registers:
Peter
juliusjai
Hi Peter,
Thank you very much.
Julius
李丽丽
Have you successed?Any replay would be greatful
