Build KK4.4.3 Android image:V8MediaQueryList.h: No such file or directory
albert_zhang
Today, when i try to build android image for i.mx6q-sd board, and i follow Android_User's_Guide but i didn't patch android_KK4.4.3_2.0.0-ga_omxplayer_source.tar.gz and android_KK4.4.3_2.0.0-ga_wfdsink_source.tar.gz packages. This is my command order after c_patch command:
1.source build/envsetup.sh
2.lunch sabresd_6dq-eng
3.make
And then, i got a fatal error:external/chromium_org/third_party/WebKit/Source/core/css/MediaQueryListListener.cpp:23:30: fatal error: V8MediaQueryList.h: No such file or directory
I search this error on community but i didn't find the same problem.
Does anyone meet this? Hope give me some advice.
albert
jamesbone
Hello Albert,
The issue would be related that our GIT server where move to Code Aurora, here is the link
i.MX - Code Aurora
albert_zhang
Hi jamesbone,
I see the link, but there are many repositories. I wanna build KK4.4.3_2.0.0 version for i.MX6Q-SD board but i get this error, I really don't know which repository, which branch and which version should i clone.I just follow Android_User's_Guide(KK4.4.3_2.0.0), should i repo again? Could you provide clone link?
albert
