TEA1716T与TEA1713兼容吗?是否可以直接用TEA1716T替换250W电路中的TEA1713,不改变电路?
yangpengyw
我在官网TEA1716T查到的250W用户文档资料里是TEA1713,里面的电路是否把TEA1713换成TEA1716就可以了?
TomasVaverka
I am not sure if I correctly understood your question, but the TEA1713 is pin-to-pin compatible with TEA1716 and is more suitable for applications that do not have severe requirements on burst mode operation and do not require a very low standby power consumption.
Tomas
yangpengyw
I'd like to use 1716 to do a 250 W switching power supply.The circuit diagram is made of 1713 which in the NXP website user guide.Can I use this circuit by change nothing except 1713?
TomasVaverka
Yes, you can simply replace the TEA1713 by TEA1716 without any other modifications.
Tomas
yangpengyw
Where can i buy LP3925 and QP-3325?
yangpengyw
i would be very grateful if you could give me a TEA1713 250 W demo board.
