Why data can not be alloced in specified flash area? - MC9S12XEQ512
Question asked by Michael Tang on Dec 16, 2008
Latest reply on Dec 16, 2008 by CompilerGuru
Hi All,
The MCU is MC9S12XEQ512.
In PRM file,  a flash area CONFIG_AREA defined and user segment USER_CONFIG_SECTION is placed into the segment.
SEGMENTS
CONFIG_AREA = READ_ONLY   0xFE8000 TO 0xFE83FF;  /* Configuration Area: 1024 bytes*/
END
PLACEMENT
USER_CONFIG_SECTION INTO CONFIG_AREA;
END
Added p/n to subject.
In source code
#pragma CONST_SEG __GPAGE_SEG USER_CONFIG_SECTION
const T_uConfigHeader CFG_Header = {
    (T_u16)0x00u,
    (T_u16)123u,
    (T_u32)0x01020304u,
    (T_u16)0x00u
const FileID_STRUCT CFG_BeginFileID = {
    (T_u8) BNG_FILEID_BYTE0_VALID,
    (T_u8) BNG_FILEID_BYTE1_VALID,
    (T_u8) BNG_FILEID_BYTE2_VALID,
    (T_u8) BNG_FILEID_BYTE3_VALID,
    (T_u8) BNG_FILEID_BYTE4_VALID,
const T_uCFGRecord CFG_Records[CFM_GCC_MAXNOOFRECORDS] = {
        (T_u8)0x11u, (T_u8)0x00u, (T_u16)0x0014u,(T_u8)0x00u, (T_u8)0x10u, (T_u8)0x00u, (T_u8)0x03u, (T_u8)0x00u, (T_u8)0x00u
        (T_u8)0x20u, (T_u8)0x00u, (T_u16)0xC000u,(T_u8)0x10u, (T_u8)0x1Fu, (T_u8)0x11u, (T_u8)0x12u, (T_u8)0x13u, (T_u8)0x14u
        (T_u8)0x20u, (T_u8)0x00u, (T_u16)0xC001u,(T_u8)0x12u, (T_u8)0x2Fu, (T_u8)0x21u, (T_u8)0x22u, (T_u8)0x23u, (T_u8)0x24u
But when I complied the code and checked map file, only CFG_Header and CFG_Records put in USER_CONFIG_SECTION, and CFG_BeginFileID is lost!
SECTION: "USER_CONFIG_SECTION"
  CFG_Header CFG_Records
usr_cfg.obj:
  CFG_BeginFileID
Could you please tell me why CFG_BeginFileID can not alloced in USER_CONFIG_SECTION?
Thanks!
Message Edited by NLFSJ on 2008-12-16 09:49 PM
