MKM14Z64ACHH5  How to use the analog comparator.
Question asked by jun yamada on Nov 1, 2018
Latest reply on Nov 5, 2018 by jun yamada
I am using CORTEX-M0+ MKM14Z64ACHH5.
In the data sheet, it is described as follows.
Two analog comparators (CMP) with 6 bit DAC and programmable reference input
I would like to use this comparator as port input, so please tell me the following points.
① In the KM Family Reference Manual Figure 27-1. CMP, DAC and ANMUX Block Diagram
There are reference inputs 0 to 6, but is this supported on the next pin?
Which pin corresponds to the reference input?
PIN# name
14 SDADP 0
15 SDADM 0
16 SDADP 1
17 SDADM 1
20 SDADP 2 / CMP 1 P 2
21 SDADM 2 / CMP 1 P 3
24 SDADP 3 / CMP 1 P 4
23 SDADM 3 / CMP 1 P 5
② Does SDADPx and SDADMx have a combination of positive input and negative input of the comparator?
③ What is the reference voltage of CMP1P2 to CMP1P5?
④ The name of SDADPx or CMP 1 Px can not be found in the manual. Where do you examine these usage?
⑤ Is there a sample code to use as an input port?
Sorry to trouble you, but I want to know soon, thank you.
I am sorry that my English is not good.
