MCUExpresso's ConfigTool
EugeneHiihtaja
Senior Contributor I
Hi !
I'm using Config tool what is embedded ti MCUExpresso. I have 2 different Pin configurations and I can't create
different Pin label and identifier for the same GPIO pin.
It would be nice if in one Functional group, pin have one label and identifier and on other group - other labels and identifier.
If this possible right now ?
Eugene
liborukropec
Hello Eugene,
current Config Tools v4.1 and also upcoming v5.0 supports for one pin one label (common practice is to use slash "/" as separator for different functions, e.g. "J2[1]/D12[4]/LEDRGB_GREEN"). But in each functional group you can have different identifier. Using popup menu on the pin row e.g. in "Routed Pins" view select menu "Label and Identifier":
in the opened dialog you can define more identifiers - see the semicolon - it is the separator:
Now you can choose different identifier in each functional group.
Libor
EugeneHiihtaja
Hi Libor !
Thank you !
Do you have idea when version v5.0 available ?
Eugene
liborukropec
Hi Eugene,
I cannot say exact date, but it can be expected by the end of this year.
Libor
