JN-SW-4141 and JN-AN-4168 SDK do not support function "sprintf"
ls_ubuntu
c:/nxp/bstudio_nxp/sdk/tools/ba-elf-ba2-r36379/bin/../lib/gcc/ba-elf/4.7.4/../../../../ba-elf/lib/mcpu_jn51xx_sizeopt\libc.a(lib_a-glue.o): In function `_sbrk':
/ba_toolchain/r36379/source/gcc-4.7.4-ba-r36379-build/ba-elf/mcpu_jn51xx_sizeopt/newlib/libc/sys/basim/../../../../../../../gcc-4.7.4-ba-r36379/newlib/libc/sys/basim/glue.c:75: undefined reference to `end'
/ba_toolchain/r36379/source/gcc-4.7.4-ba-r36379-build/ba-elf/mcpu_jn51xx_sizeopt/newlib/libc/sys/basim/../../../../../../../gcc-4.7.4-ba-r36379/newlib/libc/sys/basim/glue.c:75: undefined reference to `_stack'
/ba_toolchain/r36379/source/gcc-4.7.4-ba-r36379-build/ba-elf/mcpu_jn51xx_sizeopt/newlib/libc/sys/basim/../../../../../../../gcc-4.7.4-ba-r36379/newlib/libc/sys/basim/glue.c:75:(.text+0x197): relocation truncated to fit: R_BA_8 against undefined symbol `_stack'
collect2.exe: error: ld returned 1 exit status
mario_castaneda
You can use DBG_vPrintf(TRUE, "Initialising ...");
Include the "dbg.h" file
Mario
ls_ubuntu
hi
thank you for answer, but I have use the UART0 for DBG, I want  use sprintf to combine string and transmit using UART1
mario_castaneda
Hi Liushuai,
You can set the DBG for the UART1 as well and transmit data.
You can not use the DBG for both UARTs.
Mario
ls_ubuntu
thanks your help, but I have use the UART0 for DBG to print Dubeg infomation ,I need to use UART0 and UART1 simultaneously
