Hi Stevec,
you have to replace the ansi library since the one you are usnig in the project refers to TINY memory model.
The library has to match with project memory model otherwise it's not possible to link them together.
I'd suggest you to replace file
ansitis.lib by
ansiis.lib.
The Libs are located here by default:
"<CodeWarrior home directory>\lib\HC08c\lib\*.lib"
For more information about the available ansi libraries I'd suugest you to see:
"<CodeWarrior home directory>\lib\HC08c\readme.txt"
Stanish
