for some reason, anything displayed on my lcd is shifted up by about 13 pixels. i tried setting vsync front porch in the device tree and that didn't help. the only thing that works is using the fbset command "fbset -upper 13" which shifts the screen down to the correct position. How do I make this change permanent?
Please try to play with upper margin option of the framebuffer.
Victor
That's what I'm asking how to do. As I said I can set temporarily the margin with fbset but how do i make the change permanent?
