When need to copy bin file to a storage device (RAM or flash depends on linker configuration),
Is it only required that we copy the .bin format into the start address of text ? (which is the text start address)
Or does bin format also contains data that need to be written into another start address ? I
Thank you,
ranran
In general, it depends on ...
Often .bin file is just memory image without any structure and headers.
What file do You mean? What is problem environment?
Yuri
Note: If this post answers your question, please click the Correct Answer
button. Thank you!
