I am working on IMX7DSABRED board. In cortex-A7 I am booting Linux kernel and cortex-M4 is running with freeRTOS. To run the application after power on/off every time I need to enter commands to load bin file in u-boot. I tried with OCRAM and TCM linker file.
I want to load bin file only once. How can I fix this issue?
Thanks and Regards.
Ravi Ranjan Kumar.
You can take a look to the following post :
