PN5180 dont work and dont make the firmware
cleberdrums
Hi, I have the same problem of a mate, somebody can help me how you fixed this? I buyed the PN5180A0HN/C1E and the secure firmware update entered but the busy pin dont going a high or low some times and cannot upgrade the firmware and dont work. have some idea i can make for fix this or the chip is scrap?
cleberdrums
Thanks for answer.
I finded the problem, a Short Circuit in SCK line, because this not communicate, and now works fine.
Thanks a lot!
Kan_Li
How did you perform the secure firmware update? By NXPCockpit? Please kindly clarify.
Thanks for your patience!
Kan
cleberdrums
Thanks for answer.
Thanks a lot!
