I have been building Android 8.0.0 for my i.MX6Solo but ran into problems booting. The services are getting started and almost immediately killed again. This starting/getting killed continues forever. I have attached boot logs.
As suggested in several other similar problems I have tried adding "androidboot.selinux=permissive androidboot.dm_verity=disable" to bootargs but it didnt solve the problem.
What can I do to successfully boot? Any advice or suggestion would be appreciated
Are you using a custom board?
Diego.
