How to play audio on i.mx8qxp mek ?
chen_jackcw
Hi sirs,
I test the imx8qxp mek board under Android BSP, connect a speaker to its audio io board or headphone jack on CPU board. Then play mp3 music by using audio player app. There is no sound output.
Should I do anything else to play the audio ? like install codec or any driver or rebuild the BSP with other configurations ?
Jack
n3820fjmn2k2q
Hi Jack.
Please watch this.
Maybe its same problem.
i.MX8Q Android How to enable WM8960 output
Makoto
jimmychan
The board that you are using is not public yet. We don't have document to support your issue. Please contact the local FAE (the person who gave you the board?) to provide you the BSP and the documentation of the board.
