S32K144EVB keep show bootloader folder after connect USB
liaowyne
I am tried to flash opensda firmware, but after access bootloader folder and try to flash firmware, the board can't get out the bootloader mode, please help!!!
danielmartynek
If I understand, you want to use the MSD Flash Programmer to program an s-record into the S32K144.
Have you followed the steps in the EVB Quick Start Guide?
liaowyne
Yes, but I can't find  the openSDA Application file after click the SDA_INFO.HTML.
That website show as below.
danielmartynek
Download the Firmware Apps
liaowyne
Hi Daniel,
I have downloaded that .zip file but there are no named S32K144 firmware file in there.
And I have tried all S32 file to put to the bootloader folder nothing happens but file been removed.
danielmartynek
I see there is one for S32K144 in the .zip file:
