I.MX6Q Mic. Recording Problem!!
Question asked by Jason Oh on Oct 17, 2018
Latest reply on Dec 9, 2019 by ffff ff
Good Day!
My name is Jason Oh from Korea(South).
I have ported android 7.1.2 successfully to our custom  i.mx6q board.
CPU       : i.MX6Q
OS         : Android 7.1.2 Nougat (N7.1.2_2.0.0, 4.9 kernel)
CODEC : WM8960
When I record microphone, it has recorded normally around 5 seconds, then errors occur.
Could someone help me to fix this problem?
If you need more infomation (schematic, source code, etc..), please tell me!
Thank You!!
*Logcat Output)
0-12 06:52:24.431   277   324 I audio_hw_primary: start_output_stream_primary... -1494403328, device 2
10-12 06:52:24.434   544   644 I MediaFocusControl:  AudioFocus  requestAudioFocus() from uid/pid 10051/1192 clientId=android.media.AudioManager@b96226f req=1 flags=0x0
10-12 06:52:24.460   277   605 W audio_hw_primary: get_input_buffer_size size = 48, channel_count = 1
10-12 06:52:24.461   277   605 W audio_hw_primary: In channels 1, rate 8000, devices 0x80000004
10-12 06:52:24.461   277   605 W audio_hw_primary: get_input_buffer_size size = 48, channel_count = 1
10-12 06:52:24.462   277  1230 I AudioFlinger: AudioFlinger's thread 0xa56833c0 ready to run
10-12 06:52:24.465   285   285 W AudioRecord: Server adjusted notificationFrames from 1024 to 160 for frameCount 2048
10-12 06:52:24.466   285  1231 I MediaPlayerService: MediaPlayerService::getOMX
10-12 06:52:24.467   285  1231 I OMXClient: MuxOMX ctor
10-12 06:52:24.467   282   297 I OMXMaster: makeComponentInstance(OMX.google.amrnb.encoder) in mediacodec process
10-12 06:52:24.470   285  1231 I MediaCodec: MediaCodec will operate in async mode
10-12 06:52:24.472   282   282 E OMXNodeInstance: setConfig(11a0038:google.amrnb.encoder, ConfigPriority(0x6f800002)) ERROR: Undefined(0x80001001)
10-12 06:52:24.472   285  1231 I ACodec  : codec does not support config priority (err -2147483648)
10-12 06:52:24.478   285   285 I MPEG4Writer: limits: 4294967295/0 bytes/us, bit rate: 12200 bps and the estimated moov size 3195 bytes
10-12 06:52:24.479   285  1227 I MediaCodecSource: MediaCodecSource (audio) starting
10-12 06:52:24.709   277   324 W audio_hw_primary: card 0, port 0 device 0x2
10-12 06:52:24.709   277   324 W audio_hw_primary: rate 44100, channel 2 period_size 0xc0
10-12 06:52:24.710   277  1230 W audio_hw_primary: in_set_parameters input_source=1;routing=-2147483644
10-12 06:52:24.711   277  1229 W audio_hw_primary: start_input_stream....
10-12 06:52:24.712   285  1227 I MediaCodecSource: MediaCodecSource (audio) started
10-12 06:52:24.717   277  1229 W audio_hw_primary: card 0, port 0 device 0x4
10-12 06:52:24.717   277  1229 W audio_hw_primary: rate 44100, channel 2 format 0, period_size 0xc0
10-12 06:52:24.726   277   324 W AudioFlinger: write blocked for 295 msecs, 4 delayed writes, thread 0xa6983640
10-12 06:52:24.767   285  1236 I MPEG4Writer: setStartTimestampUs: 9827
10-12 06:52:24.767   285  1236 I MPEG4Writer: Earliest track starting time: 9827
10-12 06:52:27.806   277   324 W audio_hw_primary: do_out_standby... -1494403328
10-12 06:52:43.248   277  1229 E audio_hw_primary: get_next_buffer() pcm_read_wrapper error -1
10-12 06:52:43.248   277  1229 E audio_hw_primary: get_next_buffer() pcm_read_convert error -1
10-12 06:52:43.248   277  1229 W audio_hw_primary: ret -1, pcm read error cannot read stream data: I/O error.
10-12 06:52:43.254   277  1229 E audio_hw_primary: get_next_buffer() pcm_read_wrapper error -16
10-12 06:52:43.254   277  1229 E audio_hw_primary: get_next_buffer() pcm_read_convert error -16
10-12 06:52:43.254   277  1229 W audio_hw_primary: ret -16, pcm read error cannot prepare channel: Device or resource busy.
10-12 06:52:43.260   277  1229 E audio_hw_primary: get_next_buffer() pcm_read_wrapper error -16
10-12 06:52:43.260   277  1229 E audio_hw_primary: get_next_buffer() pcm_read_convert error -16
10-12 06:52:43.260   277  1229 W audio_hw_primary: ret -16, pcm read error cannot prepare channel: Device or resource busy.
10-12 06:52:43.267   277  1229 E audio_hw_primary: get_next_buffer() pcm_read_wrapper error -16
10-12 06:52:43.267   277  1229 E audio_hw_primary: get_next_buffer() pcm_read_convert error -16
10-12 06:52:43.267   277  1229 W audio_hw_primary: ret -16, pcm read error cannot prepare channel: Device or resource busy.
10-12 06:52:43.273   277  1229 E audio_hw_primary: get_next_buffer() pcm_read_wrapper error -16
10-12 06:52:43.273   277  1229 E audio_hw_primary: get_next_buffer() pcm_read_convert error -16
10-12 06:52:43.273   277  1229 W audio_hw_primary: ret -16, pcm read error cannot prepare channel: Device or resource busy.
10-12 06:52:43.279   277  1229 E audio_hw_primary: get_next_buffer() pcm_read_wrapper error -16
10-12 06:52:43.279   277  1229 E audio_hw_primary: get_next_buffer() pcm_read_convert error -16
10-12 06:52:43.279   277  1229 W audio_hw_primary: ret -16, pcm read error cannot prepare channel: Device or resource busy.
10-12 06:52:43.285   277  1229 E audio_hw_primary: get_next_buffer() pcm_read_wrapper error -16
10-12 06:52:43.285   277  1229 E audio_hw_primary: get_next_buffer() pcm_read_convert error -16
10-12 06:52:43.285   277  1229 W audio_hw_primary: ret -16, pcm read error cannot prepare channel: Device or resource busy.
10-12 06:52:43.291   277  1229 E audio_hw_primary: get_next_buffer() pcm_read_wrapper error -16
10-12 06:52:43.291   277  1229 E audio_hw_primary: get_next_buffer() pcm_read_convert error -16
10-12 06:52:43.291   277  1229 W audio_hw_primary: ret -16, pcm read error cannot prepare channel: Device or resource busy.
