How to test the GPU of imx
westbrook
Hi Guys,
I am using imx6 solo with X11, kernel 4.9.11, gpu driver 6.2.2 in kernel, and I add following gpu packages to filesystem:
imx-gpu-viv-6.2.2
gpu-viv-g2d-6.2.2
xf86-video-imx-viv-6.2.2.p0
From /var/log/Xorg.0.log, I can see that the GPU driver loaded successfully. I want to know, how to test the GPU functions, it should be some demos?
Thank you in advance.
BR,
Xiao
Hi Xiao
one can test with gpu unit test:
imx-test.git - i.MX Driver Test Application Software
westbrook
Hi Igor,
Thanks for your quick reply, I will try this tool.
Xiao
