Whether display port (DP) supported in i.MX8M(fsl-yocto-L4.9.51_mx8mq-ga).
If supported where can I get the firmware binaries and porting guide for the same?
Thanks in advance.
Yashavantha
Hello Yashavantha,
the current BSPs for the 8M don't include support for the eDP. We are working on a new BSP 4.14.x which should support the eDP somehow, but as the EVK has no DP connector, you might need to apply changes and build your own image.
So watch out for the new BSP release later this year.
Benrhard.
Hi Yashavantha
supported modules are described in Release Notes included in linux
documentation available on
Display Port(DP) is not supported, one can apply to nxp local marketing office
to get additional details about its support.
