Problems with pulseaudio, bluez, and ofono on iMX8 fsl-imx-wayland
Question asked by Mustafa Ozcelikors on Oct 9, 2018
Latest reply on Mar 25, 2019 by Mohammed sha
Hello all,
I have been trying to develop an application that has media playback, media control, and telephony with i.MX8 QuadMax MEK board. I use Yocto fsl-imx-wayland distro, which uses Wayland desktop with Weston compositor. Moreover, I use bluez-5.41, ofono-1.18, pulseaudio-12.2 and libqofono-0.92. The application runs in Ubuntu pretty smoothly with no apparent problems. The application also runs on i.MX8 Yocto bsp, until some daemons decide to crash. So it's not that my application works doesn't work as expected, it is that I'm getting very weird ofono slow-downs, disconnections, crashes as well as pulseaudio errors on iMX8 platform, all occasionally.
I start bluetooth, ofono, and pulseaudio by using the following command:
# Start dbus and export bus address
export $(dbus-launch) && {
    export $DBUS_SESSION_BUS_ADDRESS
    /usr/libexec/bluetooth/bluetoothd  -d -n  2>&1 | tee /opt/bluetooth.log &
    systemctl restart ofono
    pulseaudio --realtime 2>&1 | tee /opt/pulse.log &
The reason I export dbus session address is because pulseaudio complains when --system mode is used. I wish there were a pulseaudio daemon available, but I don't think its daemonized yet.
My dbus configuration in /etc/dbus-1/system.conf is as follows:
<busconfig>
  <!-- ../system.conf have denied everything, so we just punch some holes -->
  <policy user="root">
    <allow own="org.pulseaudio"/>
    <allow own="org.pulseaudio.Server"/>
    <allow own="org.ofono"/>
    <allow send_destination="org.ofono"/>
    <allow send_interface="org.ofono.SimToolkitAgent"/>
    <allow send_interface="org.ofono.PushNotificationAgent"/>
    <allow send_interface="org.ofono.SmartMessagingAgent"/>
    <allow send_interface="org.ofono.PositioningRequestAgent"/>
    <allow send_interface="org.ofono.HandsfreeAudioAgent"/>
    <allow own="org.bluez"/>
    <allow send_destination="org.bluez"/>
    <allow send_interface="org.bluez.Agent1"/>
    <allow send_interface="org.bluez.MediaEndpoint1"/>
    <allow send_interface="org.bluez.MediaPlayer1"/>
    <allow send_interface="org.bluez.ThermometerWatcher1"/>
    <allow send_interface="org.bluez.AlertAgent1"/>
    <allow send_interface="org.bluez.Profile1"/>
    <allow send_interface="org.bluez.HeartRateWatcher1"/>
    <allow send_interface="org.bluez.CyclingSpeedWatcher1"/>
    <allow send_interface="org.bluez.GattCharacteristic1"/>
    <allow send_interface="org.bluez.GattDescriptor1"/>
    <allow send_interface="org.freedesktop.DBus.ObjectManager"/>
    <allow send_interface="org.freedesktop.DBus.Properties"/>
  </policy>
  <policy at_console="true">
  </policy>
 <policy user="pulse">
  </policy>
<policy group="lp">
</policy>
</busconfig>
My pulse configuration in /etc/pulse/default.pa is as follows:
#!/usr/bin/pulseaudio -nF
# This file is part of PulseAudio.
# PulseAudio is free software; you can redistribute it and/or modify it
# under the terms of the GNU Lesser General Public License as published by
# the Free Software Foundation; either version 2 of the License, or
# (at your option) any later version.
# PulseAudio is distributed in the hope that it will be useful, but
# WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
# General Public License for more details.
# You should have received a copy of the GNU Lesser General Public License
# along with PulseAudio; if not, see <http://www.gnu.org/licenses/>.
# This startup script is used only if PulseAudio is started per-user
# (i.e. not in system mode)
.fail
### Automatically restore the volume of streams and devices
#load-module module-device-restore
load-module module-stream-restore restore_device=false
load-module module-card-restore
### Automatically augment property information from .desktop files
### stored in /usr/share/application
load-module module-augment-properties
### Should be after module-*-restore but before module-*-detect
#load-module module-switch-on-port-available
### Load audio drivers statically
### (it's probably better to not load these drivers manually, but instead
### use module-udev-detect -- see below -- for doing this automatically)
#load-module module-alsa-sink device=hw:1,0
#load-module module-alsa-source
#load-module module-oss device="/dev/dsp" sink_name=output source_name=input
#load-module module-oss-mmap device="/dev/dsp" sink_name=output source_name=input
#load-module module-null-sink
#load-module module-pipe-sink
### Automatically load driver modules depending on the hardware available
.ifexists module-udev-detect.so
load-module module-udev-detect
.else
### Use the static hardware detection module (for systems that lack udev support)
load-module module-detect
.endif
### Automatically connect sink and source if JACK server is present
.ifexists module-jackdbus-detect.so
.nofail
load-module module-jackdbus-detect channels=2
.fail
.endif
### Automatically load driver modules for Bluetooth hardware
.ifexists module-bluetooth-policy.so
load-module module-bluetooth-policy ag=true
# auto_switch=2
.endif
.ifexists module-bluetooth-discover.so
load-module module-bluetooth-discover headset=auto
# headset=ofono
.endif
### Load several protocols
.ifexists module-esound-protocol-unix.so
load-module module-esound-protocol-unix
.endif
load-module module-native-protocol-unix auth-anonymous=1
### Network access (may be configured with paprefs, so leave this commented
### here if you plan to use paprefs)
#load-module module-esound-protocol-tcp
#load-module module-native-protocol-tcp
#load-module module-zeroconf-publish
### Load the RTP receiver module (also configured via paprefs, see above)
#load-module module-rtp-recv
### Load the RTP sender module (also configured via paprefs, see above)
#load-module module-null-sink sink_name=rtp format=s16be channels=2 rate=44100 sink_properties="device.description='RTP Multicast Sink'"
#load-module module-rtp-send source=rtp.monitor
### Load additional modules from GConf settings. This can be configured with the paprefs tool.
### Please keep in mind that the modules configured by paprefs might conflict with manually
### loaded modules.
#.ifexists module-gconf.so
#.nofail
#load-module module-gconf
#.fail
#.endif
### Automatically restore the default sink/source when changed by the user
### during runtime
### NOTE: This should be loaded as early as possible so that subsequent modules
### that look up the default sink/source get the right value
load-module module-default-device-restore
### Automatically move streams to the default sink if the sink they are
### connected to dies, similar for sources
load-module module-rescue-streams
### Make sure we always have a sink around, even if it is a null sink.
load-module module-always-sink
### Honour intended role device property
load-module module-intended-roles
### Automatically suspend sinks/sources that become idle for too long
load-module module-suspend-on-idle
### If autoexit on idle is enabled we want to make sure we only quit
### when no local session needs us anymore.
.ifexists module-console-kit.so
load-module module-console-kit
.endif
.ifexists module-systemd-login.so
load-module module-systemd-login
.endif
### Enable positioned event sounds
load-module module-position-event-sounds
### Cork music/video streams when a phone stream is active
load-module module-role-cork
### Modules to allow autoloading of filters (such as echo cancellation)
### on demand. module-filter-heuristics tries to determine what filters
### make sense, and module-filter-apply does the heavy-lifting of
### loading modules and rerouting streams.
load-module module-filter-heuristics
load-module module-filter-apply
### Make some devices default
# Make HDMI default  #Check with pactl list short sinks
set-default-sink alsa_output.platform-sound-hdmi.stereo-fallback
#set-default-source input
I only commented the following,
#load-module module-switch-on-connect
and added
Unfortunately, with the commented-out modules, when I get a call and call ends, a2dp sink changes to a device that I don't want. So set-default-sink do not work. So commenting these out works for me. Maybe it triggers something bigger. I'd like to get your opinion.
I have the following in my ~/.asoundrc ALSA configuration. This might not be the best way to define asoundrc, since I also use pulseaudio. I'd also use your opinions here.
# Making the HDMI device default
pcm.!default {
    type hw
    card 2
    device 0
I have the following cards:
**** List of PLAYBACK Hardware Devices ****
card 0: cs42888audio [cs42888-audio], device 0: HiFi cs42888-0 []
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 1: wm8960audio [wm8960-audio], device 0: HiFi wm8960-hifi-0 []
  Subdevices: 1/1
card 1: wm8960audio [wm8960-audio], device 1: HiFi-ASRC-FE (*) []
  Subdevices: 1/1
card 2: imxaudiohdmi [imx-audio-hdmi], device 0: imx8 hdmi snd-soc-dummy-dai-0 []
  Subdevices: 1/1
Last but not least, I use CSR v4.0 bluetooth module (china made), I also suspect maybe disconnection problems have something to do with the module.
Now, coming to the problems I'm having..
Almost everytime I launch pulseaudio with pulseaudio --realtime, I get the following messages:
W: [pulseaudio] module-loopback.c: Configured latency of 200.00 ms is smaller than minimum latency, using minimum instead
W: [pulseaudio] module-loopback.c: Cannot set requested sink latency of 68.25 ms, adjusting to 100.00 ms
W: [pulseaudio] module-loopback.c: Cannot set requested source latency of 143.25 ms, adjusting to 250.00 ms
I also get the following occasionaly when connection switches from HFP to A2DP or vice versa:
alsa-util.c: Got POLLNVAL from ALSA
When I launch my application (which basically only uses dbus in order to communicate with bluez & ofono), the application runs for a while. With the perfect luck, I get around 5 minutes of smooth media transmission, phone rings and I'm able to talk to the person, then phone hangs up and everything continues as expected. What I'm saying is it is not really deterministic when the errors or problems occur. That's making the solution very difficult to find, and problem very difficult to reproduce. It's just the courtesy of bluez, pulseaudio and ofono. Sometimes, it happens when I have a 4minute+ call on the phone and hang up, the a2dp does not come back live and I get the following constantly in bluez log:
bluetoothd[10544]: ../bluez-5.41/profiles/audio/avdtp.c:avdtp_parse_cmd() Received START_CMD
bluetoothd[10544]: ../bluez-5.41/profiles/audio/avdtp.c:avdtp_start_cmd() Rejecting (49)
bluetoothd[10544]: ../bluez-5.41/profiles/audio/avdtp.c:session_cb()
Sometimes when I send hang up command through DBUS, for example, I get the following in dbus-monitor --system. It says org.freedesktop.DBus.Error.AccessDenied, but I think this error might stem from the fact that ofono had already crashed and now I'm unable to send commands:
method return time=1539068262.046519 sender=:1.26 -> destination=:1.23 serial=21 reply_serial=114
error time=1539068262.046600 sender=org.freedesktop.DBus -> destination=:1.26 error_name=org.freedesktop.DBus.Error.AccessDenied reply_serial=21
   string "Rejected send message, 1 matched rules; type="method_return", sender=":1.26" (uid=0 pid=30830 comm="pulseaudio --realtime ") interface="(unset)" member="(unset)" error name="(unset)" requested_reply="0" destination=":1.23" (uid=0 pid=30827 comm="/usr/sbin/ofonod -d -n ")"
Similarly, when ofono Aborts with absolutely no error log whatsoever, I get something like the following in libqofono:
Hangup  failed: QDBusError("org.freedesktop.DBus.Error.NoReply", "Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.")
Oh, and also, when I want to pause the HFP connection by simply hitting bluetooth switch while I'm in a call, and get it back on, I get the following and then audio is lost:
E: [bluetooth] module-bluez5-device.c: Failed to read data from SCO socket: Connection reset by peer
E: [pulseaudio] backend-ofono.c: Deferred setup failed on fd -1: Transport endpoint is not connected
W: [pulseaudio] backend-ofono.c: New audio connection invalid arguments (path=/card_1 fd=31, codec=1)
In the meantime, ofono gives no error that I can see:
ofonod[8891]: ../ofono-1.18/src/modem.c:get_modem_property() modem 0x8cde110 property DevicePath
ofonod[8891]: ../ofono-1.18/src/modem.c:get_modem_property() modem 0x8d7f7d0 property DevicePath
ofonod[8891]: ../ofono-1.18/src/modem.c:get_modem_property() modem 0x8cdfb20 property DevicePath
ofonod[8891]: ../ofono-1.18/src/modem.c:get_modem_property() modem 0x8d32130 property DevicePath
ofonod[8891]: ../ofono-1.18/src/modem.c:get_modem_property() modem 0x8d2fdd0 property DevicePath
ofonod[8891]: ../ofono-1.18/src/handsfree-audio.c:sco_accept() SCO connection setup between local: 00:1A:7D:DA:71:15 and remote: D8:5B:2A:5B:7B:E6
ofonod[8891]: ../ofono-1.18/src/handsfree-audio.c:send_new_connection() 0x8ce5530, fd: 11, codec: 1
ofonod[8891]: ../ofono-1.18/drivers/hfpmodem/voicecall.c:clip_notify() clip_notify: +xxxxxxxxx 145 0
ofonod[8891]: ../ofono-1.18/src/voicecall.c:ofono_voicecall_notify() Got a voicecall event, status: 4, id: 1, number: +xxxxxxxxxx called_number: , called_name
ofonod[8891]: ../ofono-1.18/src/voicecall.c:ofono_voicecall_notify() Did not find a call with id: 1
ofonod[8891]: ../ofono-1.18/src/voicecall.c:ofono_voicecall_notify() Got a voicecall event, status: 0, id: 1, number: +xxxxxxxxxx called_number: , called_name
ofonod[8891]: ../ofono-1.18/src/voicecall.c:ofono_voicecall_notify() Found call with id: 1
ofonod[8891]: ../ofono-1.18/src/voicecall.c:ofono_voicecall_disconnected() Got disconnection event for id: 1, reason: 2
ofonod[8891]: ../ofono-1.18/src/handsfree-audio.c:agent_disconnect() Agent :1.16 disconnected
ofonod[8891]: ../ofono-1.18/src/handsfree-audio.c:am_agent_register() Agent :1.22 registered with the CODECs: CVSD
ofonod[8891]: ../ofono-1.18/src/handsfree-audio.c:am_agent_register() Wideband speech disabled: no mSBC support
All in all, I am really stuck trying to make bluez, ofono, and pulseaudio work at the same time. I really would appreciate a couple of pointers as to what might be the core cause of these problems.
Is it my pulseaudio & alsa configuration being not correct? Is it the dbus permissions? Is it the CSRv4.0 bluetooth dongle? or is it faulty drivers in a pre-release board (i.MX8 QuadMax MEK)? Is it the bluez, ofono, or pulseaudio versions that I'm using being buggy? Or is it the fact that pulseaudio not being fully supported in wayland?
Any guidance as to how to start tackling these issues are greately appreciated, and will hopefully be used for good on behalf of the open-source community. Thank you very much in advance.
