Example Project which uses all three Memory-Areas
Question asked by Masmiseim on Oct 9, 2018
are there any examples which run out from Hyperflash (code execution), don’t use the SD-RAM and use all three internal RAM areas (ITCM + DTCM + OCRAM). I’m searching for an example for IAR. I’m only interested in the memory-Configuration (*.icf File) and Startup-Code.
All the examples I’ve seen in the SDK use only the TCM or the SD-RAM.
Thanks and Regards
