Hi All,
I am using "imxv4l2sink" and I see that its not showing prerolled frame. It only played framed decoded after going into playing state. Can you please help to fix this ?
Hi Shiva
please check tutorial on
https://developer.ridgerun.com/wiki/index.php/IMX6_GStreamer_Pipelines_-_SDK_Turrialba
Hi igorpadykov,
Thank for the response, but there is no mention of "imxv4l2sink" in the link. I think, implementation is lacking this feature. Can you please help.
-Regards,
Shiva Kumar
Hi Shive
please look at attached Release Notes (imxv4l2sink as Video render plugin) and its usage in Linux Guide.
Linux Binary Demo Files - i.MX 6QuadPlus, i.MX 6Quad, i.MX 6DualPlus, i.MX 6Dual, i.MX 6DualLite, i.MX 6Solo, i.MX 6SoloX
Hi igor,
Attachment is having only pre-built images of kernel and boot loader. It doesn't contain release notes you have mentioned.
-Regards,
Shiva
Hi Shiva
attached red right is "Release Notes" document.
HI igor,
Any update on this ?
-Regards,
Shiva
Hi igor,
Please help with this issue. It looks like preroll frame rendering mechanism is missing in "imxv4l2sink". If so what can be done here ?
-Regards
Shiva
Hi igor,
The issue can also be reproduced in another manner. If we use "imxv4l2sink" and pause the video, in PAUSE state if we seek, frame will not be updated. But if we play, playback will start from the seeked position.
-Regards,
Shiva
Hi igor,
I was able to download the user guide from the below link. There is nothing which addresses this issue. We are using the same way its mentioned there.
https://community.nxp.com/docs/DOC-340120
-Regards,
Shiva
Hi igor,
Attachments are missing. I don't see attached documents. Please send them again.
-Regards,
Shiva
