MPC5748G for sending and receiving package
Question asked by KO HUAIMAO on Oct 9, 2018
I tried the rmii_udp example project and made board send messages to PC.
But I have no idea how to let board receive messages from PC.
I followed mpc5748g-ethernet-demo-user guide.pdf to practice mpc5748g-ethernet-LWIP-udp.rar
That is from here as the attach file.
I didn't change codes in the project as well as the default IP & MAC.
Though it built in the board successfully, no message received when I used NetAsistant to send UDP packets.
I tried to trace code by setting LEDs to check where is not executed in the program.
And found if (NetNIC_RevCheck()) cannot be access because the LED inside if cannot be traggled.
WHY the packets cannot be received and WHERE's wrong.
Hope someone gives help.
