FRDM-KEAZ128 Input Capture
elder_atom
I have modified the API  in Driver Test SW (KEAZ128FRDM_KEA128_FTM_DualEdge), but it can't work.
I use FTM0CH0 as the output source and use the FTM1CH0 as the input capture.
Please help me find the errors in my codes. If provided the Input Capture demo, it's the best.
Thanks for everyone replying.
Robin_Shen
Hi Yinwei,
Test it on FRDM-KEAZ128Q80 board, I can get the input capture interrupt.
You need connect the pin13 J4 to pin8 J6.
Please check the attached file.
Robin
Robin_Shen
Hi Yinwei,
Robin
elder_atom
Hi Robin_Shen
I want to realize the Input Capture function, but there is no Input Capture example. So I modified the KEAZ128FRDM_KEA128_FTM_DualEdge to realize the  Input Capture function, but it can't work.
Please help me find the errors in my codes. It's better If you provide me the Input Capture demo.
Thanks for your replying.
Robin_Shen
You can compare the attached codes with yours.
elder_atom
Hi Robin_Shen
    Thanks for your help sincerely. I have solved my problem according to your attached file.
