FatFS middleware Missing
songja
I am trying to add FatFS driver but I couldn't find it when I was creating a new project thru SDK wizard.
I actually added all the available drivers and everything else on SDK wizard too but still there wasn't FatFS.
However, there is still a SDK example that is using FatFS.
(I made sure that OpenSDK for K66F includes FatFS middleware too. )
does anybody know where I can add it?
Thanks.
Tags (3)
danielchen
Hi  JAEYONG
Fatfs is under the middleware components tab, not under drivers. Please see picture below
tomasvavra
This issue is still present in SDK 2.6.0.
tomasvavra
I have this problem too with LPCXpresso54618. My stack v2.5 is build with FatFs. I can see FatFs files inside the manifest xml file a import working FatFs example. But when I am cerating new project - FatFs is not listed in the middleware at all.
danielchen
Hi  JAEYONG
songja
Hello, Daniel.
Under middleware tap, I can only see "Network" and "Security".
Do I need to include other middleware when I build SDK? I remember 3 middlewares were included as default and I added freeRTOS on the top of them.
Thanks.
Jaeyong
danielchen
Yes, you need to make sure fatfs component is selected when you build SDK.
