Progressive Clock Switching for MPC5744P
Question asked by Meedan Deys on Oct 4, 2018
Latest reply on Dec 10, 2018 by Peter Vlna
Is it mandatory to enable the Progressive Clock Switching for MPC5744P ?
Can the module still operate correctly without the PCS enabled ?
I have one failed MCU (5744P) which triggers resets when I configure the PLL to 120/150 Mhz without PCS enabled. The failed MCU works OK when I enable the PCS. All of the other MCU's does not exhibit the problem.
Could it be a part issue or some EOS damage ? Any thoughts ?
