FreeRTOS on FRDM-KE06Z using MCUXpresso IDE
jeya
I'm trying to create a sample FreeRTOS project on FRDM-KE06Z dev board using MCUXpresso IDE and could't find any sample project even on the SDK_2.x_FRDM-KE0z. Did imported SDK with CMSIS DSP Library, littlefs, FatFS, sdmmc stack, Amazon-FreeRTOS Kernel. Any help Thanks.
marek-trmac
Hi Jeya Sandi,
example project are provided for a board, so they are located in boards subfolder.
In MCU IDE, once SDK installed, go to Quickstart panel and select 'Import SDK example(s)' and follow the wizard.
Marek
Marek
