Flash error while dumping for first time
software
Hello everyone,
   I am using MK66FX1M0VLQ18(mk66) controller,I am facing a problem that whenever I am dumping my code for first time I am getting following error..
Programming Done.
Contents mismatch at: 00000500H (Flash=80H Required=00H) !
Contents mismatch at: 00000502H (Flash=62H Required=3BH) !
Contents mismatch at: 00000503H (Flash=B6H Required=48H) !
Contents mismatch at: 00000504H (Flash=3FH Required=00H) !
Contents mismatch at: 00000505H (Flash=48H Required=47H) !
Contents mismatch at: 00000506H (Flash=00H Required=3BH) !
Contents mismatch at: 00000507H (Flash=47H Required=48H) !
Contents mismatch at: 00000508H (Flash=FEH Required=00H) !
Contents mismatch at: 00000509H (Flash=E7H Required=47H) !
Contents mismatch at: 0000050AH (Flash=FEH Required=3BH) !
Contents mismatch at: 0000050BH (Flash=E7H Required=48H) !
Contents mismatch at: 0000050CH (Flash=FEH Required=00H) !
Contents mismatch at: 0000050DH (Flash=E7H Required=47H) !
Contents mismatch at: 0000050EH (Flash=FEH Required=3BH) !
Contents mismatch at: 0000050FH (Flash=E7H Required=48H) !
Verify Failed!
Error: Flash Download failed - "Cortex-M4"
Please help me to solve this problem.
victorjimenez
Hello Ramakrishna B,
Could you please provide more information? For example:
Are you using the Freedom Development Platform or your custom board?
How are you trying to flash your code?
Which code are you trying to flash?
Victor.
