Openssl unable to get local issuer certificate
sagar_sakre
I am trying to get azure working on imx7sabre dual board. I've followed instructions mentioned in https://www.nxp.com/docs/en/user-guide/i.MX_Yocto_Project_User's_Guide_Linux.pdf to setup the BSP and get the shell on the board.
I've added meta-iot-cloud layer and succesfully built it. When running SimulateDevice.py (given in azure package) I get below error,
SSL routines:ssl3_get_server_certificate:certificate verify failed
The same code works perfectly on my ubuntu 16.04 machine. Upon searching I found that it is related to openssl certificate error. When I do openssl s_client -showcerts -connect google.com:443 I get the below error
Again the same command "openssl s_client -showcerts -connect google.com:443" Works well on the ubuntu machine.
A lot of people reported similar issue but there's no concrete solution. Can anybody guide me how to fix this issue?
I've attached the full error log here
Yuri
  please let me know more details how to reproduce the issue.
Yuri.
sagar_sakre
Hi Yuri, you can reproduce this issue by enabling openssl in the image package and run
on imx7 board to quickly reproduce this issue.
Yuri
   I managed to reproduce the issue, but I am afraid if it possible to find a solution
in the nearest future.
Yuri.
