Questions about the bsc9132 pin
zhengguangzhe
  • Dear responders:
Is bsc9132 for PHY pin port defined by ourselves or set by factory?
Pavel
The BSC9132 PHY signal cannot be assigned to different pins. See the Table 1 of the BSC9132 Datasheet:
https://www.nxp.com/docs/en/data-sheet/BSC9132.pdf
See also the Section 3 of the BSC9132 Reference Manual:
https://www.nxp.com/webapp/Download?colCode=BSC9132RM&Parent_nodeId=1313092522482734875086&Parent_pa...
Pavel Chubakov
