MKM34Z256XX7 Flash problem
Question asked by Avinash Bhavsar on Sep 27, 2018
Latest reply on Sep 29, 2018 by Avinash Bhavsar
kinetic series MKM34Z256VLQ7 Flash problem
I am successfully  able to access the flash and save data with creating memory blocks.
But  at the time of  erase memory block individually, The whole memory with all blocks are erase same time.
As per  application, Memory of single block has to clean and update as per the function used.
Please help with the same .
thank you .
