SPC5744PFK1AMLQ9
Question asked by MUTHUKRISHNAN P on Sep 25, 2018
Latest reply on Nov 26, 2018 by MUTHUKRISHNAN P
Hi ,
We have face issue RESET Pin is Pulled low always @10K Pull up Resistor.
Pull up resistor we modified 4k7 and 3k3 values still it is pull low.there after 100E resistor used for pull up
now RESET Pin Voltage is 0.7V. What is the actual current need RESET Pin during Power on restet and debugging mode. Data sheet defined 15mA. 3.3V and 100E pull up resistor is sufficient still voltage drop persist.
any recommendation is need for RESET Pin.
Muthukrishnan P
